turning service indicator off?
as above in a 6n2? thanks?
  • Views 784
get in your car, press and hold the little button on the clocks at the bottom, keep it held while you turn your ignition on,,, where the service display is should then turn to 3 dashes like this --- after a few seconds, then relese button and its done. hope this helps.
Edited by VDUB POLO
ahh sweet..so the same as seat leons then? cheers mucca!
