smoothed slammed MK3 polo
Make:VW
Model: Polo coupe 1ltr spi
Year/Reg: 1993 L
Mileage: 90,000 altho GT clocks read 60,000 lol
MOT: july
Tax: july
History:
Had the car for 5 years. Bought it from the daughter of an elderly guy who just died and left the car to her, had been garaged all its life and was immaculate altho the service history was lost when they cleared his house or whatever, i got the car on 70,000 with a new cambelt, now on about 90,000. I have only had to do routine maintenance in the 5 years i have had it, done both rear wheels bearings and a new fuel tank cos of a hole not rust, thats about it. Most other parts are up-rated so never got a chance to break lol
Body:
I re-sprayed the car 2 summers ago myself, the progress can be seen in my build thread which i will link further down- therefore the body work is spotless, NO rust at all, never was before spray. All body modifications were welded and contain almost no filler (pics to prove). Took my time and got it right. Colour is LB7Z silver, with extra metallic in lacquer stage, looks factory and pops in the sun!
smoothed bootlid (shape is perfect and straight, blocked out by me!), smoothed rear bumper, rain gutters, side moldings removed, shaved door handles (manual release currently but will supply auto set with remote etc) deleted ariel mount, deleted left wiper recess, completely smoothed front bumper (with lines in tact), custom black front lip, badge-less grille, oem mirror blanks
Bumper mounts tweaked to fit tight.
Shaved front and rear fenders. Doesn't scrub at all only a touch on inside full lock
Was wet sanded and buffed by me.
Always covered with megs no 16 pro paste wax
Engine and Gearbox:
Engine and Gearbox are perfect! NEVER given me a problem, starts 1st time every-time, clutch bites hard always and all gears select perfectly. Pulls smooth and well and revs hard, is often mistaken for a larger capacity engine. AAU code on 4 spd box
Has an ashley four branch manifold heat wrapped, de-cat, into Full 2 inch custom chrome stainless system. Pippercross induction cone on custom aluminum elbow with cold air feed from bumper. Recently changed the belts, dizzy, HT leads, nology silver plugs and full service with new oil and filter. New battery cos old one died during re-spray lol. Painted valve cover and some silicon hoses here and ther to replace worn ones.
I always serviced the car about every 3 months with new oil and filter with receipts to prove and a new fuel filter. altho its always in a heated garage n gets driven very infrequently.
Never leaked any oil, no oil on block etc. Never uses any water altho i have flushed it and put coolant in it several times for good measure, never uses oil. Always chokes then gets up to temp and stays there even in traffic, fans work fine.
Chassis and brakes:
Front:
Professionally tig welded and machined Custom 1 off coil-overs with shortened struts and shortened dampers, relocated steering arms, rally design 225 pound (i think) springs 7" long, with rally design top mounts. Will lower literally to the floor and back to monster truck for MOT. Ride quality is very good for height. Literally don't think ther is a lower mk3 around!
Unrated ARB bushes
Polished aluminum upper strut brace.
New rubber bushes throughout.
G40 Brake setup on front comprising:
G40 calipers and carriers refurbed with new seals and nipples, shot blasted and painted VHT silver
BREMBO max grooved and vented disks
EBC Green stuff pads
Goodridge braided aluminium brake lines
MK2 GTI 22mm master cylinder
All new HQ hard lines
Rear:
Spax argon dampers, 80mm spax springs minus 3 coils (stays in tension for MOT) , with platfrom adjustment (i think)
Rear Polished aluminium strut brace
goodridge braided lines
new pads and cylinders on drums
Handles very well and shocks most passengers, stops so hard it hurts as my GF found out on the high grip the other day! No brake fade at all.
Interior:
RECARO Half black leather grey suede seats with leg support & custom super low seat frames - super comfy hold well.
Cobra trs 3 point harnesses
E-tec 340mm brushed aluminium wheel
matching pedals and gearknob
Black floor mats with grey piping auto style HQ
GT clocks with rev counter n digital clock
Stripped rear with mdf false floor fitted and trimmed in HQ black carpet, trimmed wheel tubs, carbon fibre rear panel cover panel all balck cloth door cards.
Aluminium strut brace
Alpine CD headunit with sub-out
Lanzar mid tweets in dash, huge magnets
Pioneer 8 inch sub in custom ported box (punchy) bolted to false floor, neatly installed with tucked wires and sony 500w amp
Miscellaneous:
Sparco Aeroblade wipers
clear indicators and side repeater lenses with silvertech bulbs
new ice-white mains and side bulbs (look whiter cleaner better vis)
G40 rears lenses
Golf GTI 14x6 inch steels with - Nankang 165, 50, 14 FRONTS nearly new, - falken 512 185,50,14 REARS nearly new, 15 mm hub-centric aluminium rear spacers
valve cover, wheels, gear knob and jelly bean air freshner all match lol
runs proven 18 sec quarter miles with full interior for what its worth lol ( for 1ltr)
Aluminium tax disc holder
Been a joy to own and i hope it makes it to more shows with a new owner or recieves a big motor to match the handling brakes and looks, could be a great further project.
Passed last MOT fine.
Really reliable fun car to own.
Bad points - Front bumper ideally needs a re-spray as i ploughed some snow during snow week and its got some cracks (LOW), not terrible at all just need cleaning up- cheap fix can supply materials used originally. Centre silencer is blowing, can't lie, i run the car so low it does kiss on stuff like uneven roads lol. But i will be having it altered soon to rid this problem unless it sells 1st. passenger door is missing the bolts for the handle, pennies from a scrappa. Only negatives i can think of.
slight damage on front bumper can be seen here, better aligned now 2:
Lots of pics just to try and be fair :-)
My build thread: http://www.clubpolo.co.uk/forum/index.php?...c=75059&hl=
£1850
Edited by ELLpolo
  • Replies 51
  • Views 5.3k
interested in part ex?? Seat Leon 1.6
not thanks,ideally i want a straight sale.
bump
Bump for a sweet car, just out of interest did you get the coilover conversion kit from rally design? An what dampers did you use?
built them myself, machined the rods shorter on the lathe, re-cut the threads, drained the fluids, refilled them after shortening the body, tig welded, re-tensioned the seals etc etc LONG and difficult lol, but only way to go really low on a mk3
coils springs of the right poundage and length with ali threads were bought from rallye design online, burton power do the parts for more mulla
THE SEX
btt
alright mate car looking sweet, where you get the wheels from?
oh gosh, free bump!
btt
Hi is your car still up for grabs? And do you still have the rear seats and trim? Oh yeh and where are you from?
Just to let you know I've got cash waiting and I'm looking at buying today:) just looked through the pics again and I love it lol
very interested can i have location and mobile number to ring and talk ! got cash waiting
my mobile number is 07792840622
call anytime
located in bristol
Bump for my brother's polo, i helped with a lot of the work, as well as our dad (hes been building show winning hotrods since the 70's) and the work is a lot better than a lot "Pro" jobs and I've seen a lot of pro build cars in the works.
heres a few more pics
btt
btt
still available
actually has MOT till july and tax till then too, got all old MOT's too
still no calls, number is up now guys
bump
up we go
nice car only reson its not selling for the price is the fact its a 1ltr :/
mk3 1ltrs just dont fetch that money
sweet though mate
wow,imo the only colour coded bumper mk3 iv seen that looks right.awesome dude. glws. ;)
free bump for one of the sweetest mk3s around
