Custom 6n clocks
Hi looking to customise clock colours in my 8v 6n polo. Anyone do this?
Ta, mark.
  • Replies 11
  • Views 2k
yeah theres a thread somewhere mate
the guy who owned my polo before me done this and glued some differnt blue dials in only thing is it looks tacky, you can see the glue around the edge and they look like they was printed off with some cheap ink/paper.
Only thread I could find was kinda old? Only other thing could see is White dials but don't do for late 8v polo:-/
Which dials do you have ?
8v late model. Fuel and temp top middle. 7000rpm, 120mph.
Mark.
same as mine well, Iv changed all the L.E.D's in mine to white added a few red 1s for the red line area and fitted golf mk4 red pins.
Ill get some photos tomorrow
Edited by Po*Low*
Kool. Big job ?
How did you fit them to the red line area mate?
There's no way you can put LED's just on the redline area unless you wanted the rest going pink?
If you're on about the set you got of me which was all white? The rear of the 'red line' is simply coloured in red.
i did my dials myself it was so easy to do i just followed this thread, i hope this helps http://www.tigerstyle.co.uk/phpBB3/viewtop...=10&t=20428
and heres mine :D with my 220mph clocks!
By marckid, shot with Vodafone 360 Samsung H1 at 2010-04-21
this is the template just a little bit different with the red bits on 30-50-70 and stuff but i like it and it came out well :) just need to get some back lighting sorted on mine
:D
Although mines an early model but theres also a link to a guide for the newer models on page 2 :)
Edited by Marckid
a red
i used the white L.E.D's and the circuit board out of the clock's off you, squeezed a red SMD led next to it and it was lighting up a slight,
bit on the white bit so got a thin bit of plastic and made like a little wall so the red could not get though so it just stayed in 1 place then fitted golf Mk4 pin's
due to the set that come on the 1s you sold me was the old 1s painted red and was slowly coming though
