Cleaning Carpets.. Thouroughly!
Hi
Sounds like a bit of a weird question but my 6N was inhereted from a friend who didn't look after it well. She worked with horses and decided not to use floor mats so now there are tiny pieces of straw and hay deep in the carpet. They really piss me off and they're all over the car - my question is how can I remove them and make my carpet look new again? The car is in excellent condition and has only done 60,000 miles so I'd like to get it nice and fresh. Just the stupid stuff stuck in the carpet!
I have tried vigourous hoovering and scrubbed the carpets down with carpet cleaner and although this removed a lot of dirt, the straw is still in the carpet. Do you think I should pay a professional to do it, or is there anything I can try?
  • Replies 11
  • Views 1.7k
Have you tried a wet vac?
Works well on house carpets so it can't hurt to try it, I'm sure yo can rent one from somehwere like hss or the like :)
Thanks for the reply! When I was scrubbing the carpets with carpet cleaner, I was then sucking the water out using a wet vac. It did help to remove a lot of the dirt but the straw which is still deep in the fibers remained untouched :(
how bout a scouring pad or a brillo pad? Maybe that could shift a few pieces??
The only real way to remove bits like straw or pine needles (in my case) is to get a large needle or something similar and pick the pieces out as you vac it out. Testing on sanity but you get there eventually.
Take the carpet out, Pressure washh ;)
then if he looses the needle it will be like finding a needle in a hay stack.......
Good old tweezers ;)
I've tried tweezers which didn't really work, might have a quick go with a needle!
Is it a lengthy process trying to remove the carpet? I imagine so!
I'm a valeter and straw carpets are a pain in the ring , there is a fue good ways to clean a carpet fully ,
a wire brush and lightly run over the top ,useing this can /will change you are carpets looks by un-plucking the top!!but do work very well,
a air line with a long tool on the end gives a good clean to by shooting lots of air in to the carpet and bringing it out ,just be wairy of you are eyes it will fly out ,
there is outher ways where to use the back of a most hand 4 dog hair ect but there the 2 most efecteve and quickest ways to clean you are carpet :)
hope this helps :)
prob not what you want to hear...
take em out , good soak in some soapy water and jet wash em ..that way all the stink and dirt will come out and not soak further in
once its clean and dry , get on your knees and use tweezers for any subborn bits of straw
Thanks again for all the ideas! I might give wire brushing a go! If that doesn't work it may have to be a jetwash job! How would I go about taking the carpet out? It's only really the drivers side thats a problem!
