OMP Wheel Horn Push problems
Hey
I fitted an OMP Trecento wheel to my 6n today with a Momo airbag boss. I'm having trouble wiring up the horn push though. When I wire it up, it either doesn't work, or the horn sounds constantly.
These are the connections on the back of the horn push:
These are the connections on the boss. There is also a connection on the spigot ring that the negative spade connector was connected to when I got the boss.
Any ideas where I'm going wrong?
Edited by tezmc
  • Views 2k
For mine all I did was plug the black wire onto connector 1 on the horn and then I tried it but I wouldn't work! All you have to do is put it in with the bit of spring That sticking out of the horn button and push it fully in! Then keep pressing and rubbing the horn as oxides build up after a long time in storage!
should have updated this :D I was being a proper noob. Wired it properly and seems to be working fine now. Cheers for the help tho.
