Anyone ever changed a tensioner for Alternator belt on a 6N2?
Lol the other day my tensioner shat itself and ended up somewhere down the M25, i cant figure out how to change it, can't see the bolt that need to come off? does the alternator have to come off?
Any help would be great..
thanks peeps!
Dimz
  • Replies 11
  • Views 6.9k
hi don,mines just done the same.
did you get yours sorted?
I just changed the one on my lupo 1.4 16v, i presume its the same, kinda hard to explain though haha.the hole where the tensioner sits , round the back of it there is a 13 mm bolt that holds the tensioner in place. put the new tensioner in, tighten that bolt, then fit the belt round everythng. then once everything is in place, tehre should be a pin sticking out next to the tensioner pulley, pull that out and it should automatically tension
^^ what he said, but a picture allways helps.. aircon model shown in pic, but the non-ac models are pretty similar to be honest... you will need to remove the alternator to get access to it because the exhuast manifold and oil filter/cooler gets in the way. you will need a 16mm spanner to hold and release the tensioner to refit the belt, and a 13mm socket on a short extension to undo the bolt, alternator is also a 13mm socket/spanner
hth
thanks all,
its a 1997 1.9cl diesel engine,and the pully seems to be hanging down.
6n1 i think?
Edited by electric6
just had a closer look,the tenioner pully is still attatched.
but i can move it up and down by hand(with the belt off).
also it seems to be swiveling on its mount.
is this a relacement jobby or can i retension this?
hope this makes sense.
nah, that's bust mate, i expect one of the tabs on clock spring has broken... when they are working properly you need a spanner to turn them as the spring has quite a lot of tension
my mate changed my alternator belt the other week, took 2 min's to do, I could have done it my self. we just jacked the car up got underneath and losened the shiney pully thats just next to the alternator, gave that a twist with a spanner which losend the whole belt took the old one off and put the new one on. easy, but if your one snaped while you were driving I may have caused a bit of damage ^^
thanks all,now guess whats next???
does anyone know the part number for a replacement tensioner??
I've seen this on ebay is this it?item number 170483246925
it says a 1.2 2005
hi all,I've found this part number 028903315P .
i think it fits into this part number 028903141AP.
I'm not sure these are correct but i think they are
does anyone know how big a job this will be?
cheers.
I got mine form euro car parts mate was quite reasonable, plus you know your getting the right one
hi md,was yours the same as this?
ie 6n1polo 1997.
