Removing Glove Box Door on 6n2
Hi
Sounds like a bit of a stupid question and I've looked around but cant find any answers :?
I have broken the handle on my glove box on my 6n2 and am thinking the easiest thing would be just take the door off the glove box and replace it??
Here is the problem...I can get the top two arms out (they just pop off the cog and out), but there are two more arms at the bottom on either side that i cant get out :x
Anyone got any ideas on how they come out??
Jordan
  • Views 6.2k
It's a pain in the ass mate. mental vw designers. You've got to remove the right trim panels around the steering wheel and the lower half of the dash on the drivers side to get the glove box out..... because it's got a linking peice from the glovebox that goes across the centre console.
have fun, :thumbsup:
pm me if you get stuck.
Edited by j-bonham
you can buy the handle from vw, i broke mine and it was just a replacement. which they had in stock as well! so must be a common thing. have a look. also there is a special way of taking the lock out of the handle, so you use your original lock and put it in the new handle, its simple but I done it along time ago so cant really remember. just look at it properly and you will figure it out.
