Engine Bay Respray
I'm currently prepping the engine bay for a complete respray, but what i thought was just a bit of thick oil deposit (car is 26 years old!) is actually that amazing wax that VW put all over the car. I guess thats why its in such good condition. However, I'm having a bitch of a time trying to get rid of it, and have resorted to scraping it off with a blunt ended butter knife! I've tried sanding it, paper just clogged up, and sand blasting it just made all the sand stick to it. Anyone have any ideas as to a tried and tested solution, or else i'm going to be here until this time next year!
  • Replies 9
  • Views 1.6k
You need to get some gunk on it, strong cleaner. The stuff i used isnt on the shelf i dont think but in the end it came off with a tooth brush. It didnt come off easy at first but if you get a ice scrapper on it and a pressure washer it does start to budge.
I'll try and find out what it was i used tonight and if u can buy it.
Cheers boss. At the moment i am scraping the majority off with said knife, then using really course paper to take the rest off. I was then going to gunk and pressure wash after. Total bitch stuff! And its really hard to get out of the intricate parts etc. Still, making progress
I'd have just left it on and painted over it tbh.
As now you have moved something that has been protecting it for so many years.
Get a heat gun and some old rags. Warm wax up so it turns watery,wipe it off with rag.
Trying to paint on wax? Thats not going to work really. Paint doesnt stick to wax. Plus the finish wouldn't have been very smooth either kind of defeating the object of cleaning the bay!
And the heat gun was going to be my next idea. Now to find one!
as above heatgun and some rag
Again with above just done it my self get a heat gun on it
Wish i'd read these earlier! Have been at it with the knife and sand paper all day. Will try the heat gun 2moro. Thanks for the help
I used some spirits to get mine off, just wiped off with some elbow grease then went over it again with some warm water then polish.
