R1 Independant Throttle Bodies + 1.4 16v AFH Manifold
previously running on a 1.4 16v
R1 itbs Correctly spaced for the AFHengine
40mm ports on the itbs and inlet runners
Silicon Hosing & Jubilees - Hose could do with replacing but usable
Professionally made inlet manifold, ideally made for ported head however, but if your using ITB's you'll be after big power
NB. One cap screw is missing, but easily replacable and filters are not included
after 250 quid or swap for anything interesting
  • Replies 12
THESE ARE NOT CARBURETTORS PEOPLE
INDEPENDANT THROTTLE BODIES
GOOGLE JENVEYS IF YOU DONT HAVE A CLUE
Do you need anything else to run these like managment etc?
you may be able to run these on standard management with a remap but i would advise to run on standalone engine management
hi there was just wondering will i have to run a new loom to the injectors or will the plugs on my 1.4 fit onto the injectors on the throttle body's?
if that makes seance
thanks chris
i know what you mean, will the injector loom plugs from your 6n fit the throttle bodies.
that i dont know mate sorry, i dont have a 6n or any 6n engine looms. get a pic up of your connection and ill check the ones on these =]
Would I have to get a new inlet manifold made up for a 6n2 gti lump? Rather interested in these.
Have you ran these before saf? and what would you recommend for the standalone if so?
Max
I've not, previous owner ran it on emerald but you can use megasquirt, dta, omex.
basically check out the features list and see what works for you.
trunkz - it will fit bolt directly up, and is port matched albeit for a very subtly ported head, but will fit the 6n2 polo gti (ARC/AVY), lupo GTI and AFH cylinder heads
Yeah mate iv got an emerald set up , ill let you know.
Max
no worries...
splat
SOLD =D
