loads of bits
All parts collection from Manchester/Bolton/Knutsford area , postage via courier at buyers cost
Saf
07950 675 910
or
yousafn@gmail.com
Pics available at
http://s134.photobucket.com/albums/q104/winter_snowball
http://s16.photobucket.com/albums/b12/yousafn
more bits to come, individual pics at request if you cant find them
Interior Parts
Small Spline Coupe S Steering Wheel Removed from a 120k 1985 Polo. 20 pounds
http://i134.photobucket.com/albums/q104/wi...ll/DSC02654.jpg
320mm Steering Wheel Mounteny? No Horn Push or buttons – 20 pounds
http://i134.photobucket.com/albums/q104/wi...ll/DSC02657.jpg
Opel Manta GTE Tartan Recaros – 100 pounds
http://i134.photobucket.com/albums/q104/wi...ll/DSC02645.jpg
Mk1 Polo early wooden dash and clocks – 100 quid
Mk1 Golf Rear Shelf very good condition fabric but has sunk in one corner – 30 quid
Mk1 Golf Dashboard with glovebox lid – 40 quid
Mk1 Golf Dashboard no glovebox lid – 30 quid
Engine Parts
Polo Metal Theromostat Housing & Water Housing – Powdercoated – 10 pound
http://i134.photobucket.com/albums/q104/wi...ll/DSC02661.jpg
Mk4 Polo 1.4 16v Power Steering Pump / Alternator Mounting Bracket & Housing (not all pictured) – 15 quid
http://i134.photobucket.com/albums/q104/wi...ll/DSC02669.jpg
Mk1 Polo 1.4 16v Inlet Manifold / Fuel Rail / Injectors / EGR Valve – 40 quid
http://i134.photobucket.com/albums/q104/wi...ll/DSC02671.jpg
K&N Air Filter – 15 Pounds
http://i134.photobucket.com/albums/q104/wi...ll/DSC01329.jpg
http://i134.photobucket.com/albums/q104/wi...ll/DSC01328.jpg
Lupo GTI Spark Leads – 30 quid Coilpack 30 quid – pair for 50 quid
43k Lupo GTI Cylinder Head – 120 quid
Standard Lupo GTI Inlet Manifold complete bar throttle body – 40 quid
Fly by Wire Throttle body – 50 quid
Cable Throttle Body – 50 quid (pictured)
http://i16.photobucket.com/albums/b12/yousafn/DSC00886.jpg
K-Jet Inlet Manifold – 20 quid
Mk1 Golf GTI Throttle Body
Mk2 Golf GTI Throttle Body
1.6 GTI Head complete with inlet manifold / cam / water pipes/throttle body/isv valve, good condition – 40 pounds
Bosch ECU - 030 906 026N - 20 quid
http://s16.photobucket.com/albums/b12/yous...nt=DSC00816.jpg
Top Fill Radiator for small block vws, some damaged fins,genuine vw – 35 quid – 50 quid with freshly powdercoated rad cowling and good condition fan (pictured against a slim-lin radiator which is not for sale)
Exterior Parts
Mk1 Golf Glass 3dr
Green Tint Glass - Boot Screen / Rear OS / FRONT NS - rear boot screen 40 quid, side windows 25 each
Clear Glass - Front OS/Rear NS - 10 quid each
Mk3 polo Filler Cap Cover - Silver - 3 quid
Mk3 polo GT Rear Lights 15 quid
http://s16.photobucket.com/albums/b12/yous...nt=DSC00817.jpg
Mk3 polo1/4 Glass x 2 - 5 quid each
http://s16.photobucket.com/albums/b12/yous...=DSC00850-1.jpg
http://s16.photobucket.com/albums/b12/yous...nt=DSC00849.jpg
Brakes & Suspension Parts
Hammerite'd VW Polo Mk2 Suspension Strut Drivers - 10 quid
http://i134.photobucket.com/albums/q104/winter_snowball/DSC02676.jpg
Mk1 Golf Tie Rod Ends x 2 - Brand new - 15 quid
http://s16.photobucket.com/albums/b12/yous...nt=DSC00815.jpg
Exhausts
Powerflow Backbox Stainless Steel for Mk1 Driver 1 ¾ “ bore - 50 quid
Full mk1 GTI Standard exhaust system – 30 quid
Near New Rear Std Backbox for 1.5 Mk1 Golf – 40 quid
Mk2 golf centre box standard new – 10 quid
Full 2 ½ bore Magnex Twin Silencer System for Mk1 GTI – 3.5” round tailpipe – 200 pounds
single wiper made with oem parts
http://i134.photobucket.com/albums/q104/wi...ll/DSC01505.jpg
cam cover
inlet mani
laser cut 10mm exhaust mani flange 8v
magnex system twin silenced, 2 1/2 inch bore 3 inch tailpipe
http://i175.photobucket.com/albums/w155/Ho...10420091344.jpg
rebuild bits (less the head)
http://i23.photobucket.com/albums/b396/darren_d99/4338.jpg
fan cowling not included, just pictured for size reference, it fits a mk1 golf top fill rad
Mk1 series 1 Golf Rear Shelf very good condition fabric but has sunk in one corner – 30 quid
clearing out my golf parts now I've sold the series 1
mk1 single wiper linkage made using oem mk1 parts with upgraded mk2 motor, wiper arm and aero blade - 60 quid
chrome top radiator cover - 30 quid
new bosch coil unboxed - 30 quid
magnex stainless steel system consisting of two silencers, 3 inch outward rolled tip, 2 1/2 inch bore - 180 quid
mk1 1600 EG GTI engine in parts or complete - enquire 126k genuine miles, had fsh until shell was sold (history gone with shell)
new bosch starter motor black - 45 quid
magnecor HT leads in blue - 40 quid
K&N Panel Filter & TSR Drilled Airbox - 50 quid
Mk1 Series 1 Claspless Seat Buckles - 40 quid for pair
1600 GTI Metering head - 35 quid
black k-jet inlet manifold and throttle body - 30 quid
std dirty k-jet inlet manifold and throttle body - 20 quid
Ali Rad for big block engines (MAY require modifications to fit, and wont fit standard fan cowlings, perfect for twin slim line fans) water outlets on correct side for big blocks (cambelt end) - 40 quid
series 1 contact breaker dizzy (non electric ignition) for GTI very good working condition, points in good condition and set recently replaced in last 3k or so, as with rotor arm and cap - 45 quid
offers on below
new 1600 EG crank bearing shells
new 1600 head gasket + other gaskets and valve stem seals new
spare 1600 gti head
nos vw gearbox clutch cable rubber
new 1600 headbolts in packet
new 8v gti tensioner bracket
1600 EG timing belt new
series 1 gti 5 speed 1600 gearbox painted black
single series 1 gti alloy manky condition
mk2 gti throttle body with TPS (megasquirt conversion or modifying to fit as its same size as audi TB massive compared to std mk1 gti)
opel manta gte recaros, black/green tartan, good condition, 100 quid
all parts collection from manchester, pics on request but be patient
will post at buyers expense and liability, parcel2go/DHL have been breaking and losing parcels at an alarming rate of frequency. i travel across the UK at times on various road trips so may be able to deliver for partial fuel costs, but will ask that items are paid before being loaded into the car.
saf
07950 675 910 (please only texts between 8am - 6.30pm)
or email for fast response
yousafn@gmail.com
ps. my unit is near knutsford, welcome for people to come have a browse you might find some more goodies, will knock off pennies for people who come out to save me packaging stuff up.
if you have any requests for bits too please stick them up in the thread, if i dont have i may be able to point you in the right direction!
  • Views 635
bump for a top bloke
splat - i will be at all types on an autojumble plot, can take any parts on request
Edited by grungeisdead
ITB's, Lupo GTI Head & Lupo GTI DBW Throttle body all sold,
got a polo gti engine coming after the weekend, so full head, throttle body, inlet mani, fuel rail and injectors all for sale, I'm keeping the bottom end.
ta
