Aerosol Spraying
Basically, I'm gonna be respraying both my sills at some point using rattle cans.
Just wondered how many cans I'm gonna need for a good result?
  • Views 1k
Your going to need enough to put 3 even coats over your sills and then 2 even coats of lacquer.
The only prob with using aerosol you will struggle to achieve a perfect finish.
Just do them lightly mate.
well people say you need 10 to a whole car
so 3? 4 mabee ?
id just buy more then you have it :)
10 to a whole car is a bit stingey, when I did my sills I used about a can each, thats matt though so I'd say 3 colour + 2 primer + 3 laquer. not in that order obviously, probably about as cheap to just pay a cheap spray shop to do it. Metallic from a can isn't really cost effective, you waste a lot by applying thin coats from a distance, but you have to do that to get anywhere near a decent result.
