6n2 grill insert
Just bought a badgless grill for the tdi. They have supplied an insert for the bonnet but it is not attached to the grill. They have also supplied a super glue to attach the insert to the bonnet.
This may be abit pikey tech but was wondering if anyone had actually glued or fibreglassed the plastic insert from the badgless grill in place, instead of getting it welded up and smoothed over the insert???
usually most people just stick them on till they can afford to have the bonnet welded and smoothed
ye i knw that...but i was just wondering if anyone had actually just smoothed over the plastic insert. As regards to affording it...wouldnt be a problem as id get a mate to weld and id do the rest...but was wondering if you could save yourself the hassle by using the plastic insert as a base instead of a welded metal insert....i mean its not taking any weight so thats ok...the only thing I'm worried about is if there would be a small amount of flex in the insert or the fibreglas i would use to secure the insert to the hood...then obviously this would crack the filler.
just smoothing over it would cause it to crack eventually, welding it in place properly is the best option
Well the plastic itself is very rigid, theres no flex in it at all...so simply smoothing over this would not be a problem. What poses a problem is the material used to secure this to the bonnet. Due to the area its in, obviously just the once slamming the bonnet too hard...could cause the fibreglass to flex and then cause cracks to appear in the filler.
But never mind...appears noone has ever tried it and tbh i can live without having an insert for the time being as it isnt that noticeable.
wait a plastic insert? :S
it should be metal, even though just fibreglassing it is easy the bumps in the road send vibration through the panels and will cause it to crack very easily
don't know why its plastic though
Yes i know which is why i was asking if anyone had done this...just to see what the outcome was.
