6n interior door handles
Hi I've bought a set of chrome interior door handles for my 6n polo.
How do you remove them ?
Ta, mark.
  • Views 1.7k
I'm guessing taking the door card off??
I need to find out as mine are in the post :)
Take off door card then look at the door pulls! There's a tab on them that needs lifting with a flat screw driver and needs either pushin or pulling! Take the locking rod out and then just unclip the handle then reclip the new ones in!
Thought it was something like that :)
Kool:). How do you remove the door card? Easy job?
Mark.
To remove the doorcard firstly you need to get a flat screwdriver and pry the bottom plastic of the grab handle.
Once you pop that off there will be 2 big flathead screws to remove unscrew that and put them somewhere.
Then remove the doorpin by simply twisting it.
Around the part near the wing mirror there is some black plastic carefully pry that bit off too with screw driver or something.
It may take a bit of force so be carefull not to snap it.
After that there is plastic poppers all the way around the door cards edge you should be able to just un-pop them all and the doorcard will come off.
If you have manual windows you will need to remove the winder arm before the doorcard will come off.
Kool. I'm having a bit I bother with window winder arm? How does it come off??
Ta, mark.
