New wheels
Hi all, I'm looking to get these for my mk3 polo
http://www.minispares-online.co.uk/?cat_id...amp;prod_id=704
will I need anything else to fit these? Spriggot rings or anything like that?
If so can someone post up a link
thanks in advance
  • Views 608
Right well the pcd of the classic mini is 101.8 or something like that, now some people run this pcd on their standard wheel bolts and some people use wobble bolts. I've never had these pcd measurments so could not recommend whats best but I'm sure someone will.
As regards to spigot rings, i think the classic mini had a bore of 60.1 and the vw is 57.0. Now some people will run wheels with a larger bore without spigot rings and other people will run spigot rings, choice is down to personal opinion.
But they would fit with your standard wheel bolts and no spigots, to be on the safe side, use wobble bolts and spigots. Hope this helps dude.
Also you may need your arches pulling to get those underneath the arch.
That's great, thanks very much for your help
