Smooth Bumpers
Anyone know of any paint/filler that could be used to make the textured MKII bumpers smooth? The ones on the loon are damaged, and the rear one is a special design, so need to repair them, but there will be no way to recreate the textured effect :-(
Any ideas?
  • Replies 9
  • Views 2.9k
Any ideas?
just sand the texture off?
Thats going to take far too long! The plastic isnt really going to sand well, and will clog up any paper in seconds. Plus i need to fill in some deep scratches too, so need to raise these areas back to standard
noo, just use lots of high build primer, i did it to mine, worked perfect, the thicker you apply it the less coats you need to do
you need to spray plastic primer first tho, otherwise it will just scrape off
use a palm sander, it will de-texture them in no time, then high build plastic primer, flat back, repeat if needed untill bumper is smooth. then paint it. as for filler. isopon bumper filler is good stuff, bit expensive, but worth it as unlike regular filler its flexible.
So apply the platic primer, and then fill/apply high build primer?
I didnt think of using a palm sander, thats a good idea. And i get to use my new air compressor that way :? haha!
i would sand the texture off 1st. then fill any scuffs. you can get high build plastic primer, so you shouldnt need a separate filler primer. and if you plan to keep them black you dont need to worry what colour the primer is. halfords actually sell a really good plastic filler primer, not to pricey either.
from memory, your local to me arent you? in banbury there is a really good paint supplies company called colour-match. they are great for most of the bits you will need
Good memory! Yeah, i always use auto colour match to get all my body work stuff, and i used to work up at Tubbs Dubs too, so i learnt a bit there.
Thanks for the help
id suggest a carefull sand , at least knock the tops off the texture , it doesnt need to be mega smooth
then plastic prime , high build prime and let sit for a few days , sand with 600 wet and chances are some will poke through , prime again and sand until dead smooth
rattle cans aint that cheap...might be worth seeing if a body would lash some primer on for a few quid on the side
My local body shop might, but i have compressor and spray gun of my own, so might be able to pick up some primer and do it myself.
