Valve adjustment
Hi guys
Just a couple of questions about valve clearance and adjustment.
1) is there a guide in how to adjust them (for a Mk4 polo), I have look but not found anything (I found guides for other cars)
2) What should be the gap of the valves on a hot or cold engine (for a Mk4 polo).
The answer to the second or both questions will be appreciated.
JJ
  • Views 3.1k
valves as in inlet and exhaust valves? There is no adjustment, they use hydraulic tappits which are self-adjusting.
really???? ohh I just bought a set of feeler gauges to check the clearance. I would have thought that all cars would need to have the valves adjusted once every so often. :S
(Thanks hayesey)
Any other advice...
yeah, you deffo don't need to adjust them at all on a mk4, they all use hydraulic lifters which self adjust
