Weber DMTL
as title ^^
PM me if you have one :)
Darrell
  • Views 1.2k
I have one in pieces! Needs a rebuild kit and maybe some jets, but you can have it cheap?
would the parts be easy to find etc? does it come with the inlet..
how much?
No inlet, you'd need to make an adapter plate (easy enough) to fit your inlet.
Just had a go at rebuilding it (took about half an hour so far). Couple of screws missing but I'll get them sorted, needs a new main gasket (goes between the two halves of the carb) and all jets. These parts are readily available from fastroadcars or any other Weber spares shop.
Looking for £25 as is or I can get a rebuilt kit and give the carb a service for an extra £25. May even throw in some jets for that, but the jets are expensive and I'd rather keep them for my carb so I can play with the fuelling a bit more.
Service Kit Link
25 quid is a fucking bargain and a half man, they are worth far more than that
pm'd :-)
