damn arches are rubbing the wheel...any advice?
yo...
iv got a polo coupe and just put 14! rims with 185/60/14 tyres - the rears especially are hitting the arches with just one passenger in the front. the car is lowered 80/60.
it is touching the plastic bit which is attached/blended in with the rear bumper - if i took off the plastic will this help or do i need to get my arches rolled? i dont really want to raise the suspension then theres no point of me having lowering it!
i phoned one company ( r tec in st albans ) and they refused to do it as they said it will damage the arch and il get rust - is this true?
anyone got any advice??
nice1 :-)
Edited by koolspot
  • Replies 13
  • Views 1.4k
pics would help, but what about smaller tyres for a kick off? should eliminate the catching quite some
pop up a picture and I'm sure chrispy or i could give you advice.
buy the right size tyres in the 1st place. 165/60 and you'd be fine
yeah tyre choice sounds wrong
what about the offset on the wheels too? are they right
i took the plastic bits off on the rears and has stopped the rubbing a touch but the front rubs only when i go over bumps or potholes too fast....I'm gona put a pic of my car up with a pic of front and rear arch
can i fit 165 on14" rims? what if i went down to 185/55.14
rims are 4x100 et38
sweet..
If your Tyres are rubbing then your Vee-Dubin
:p
way too balloony.
hey buddy role the archs and get some streched tyres that will cure your problem straight away with out any doubt hope that helps and try avoid getting people in the back seats mate.
nice1...
what tyre size can i change these to...iv got 185/6014 on them now.
if i get the arches rolled will they start to rust
just stick some 50 or 55's on and u should b ok
put 165/60/14 on, doubt you will need to roll arches then as you're not particularly low, but if you do, make sure you re-seal them and they won't rust.
edit: On second thoughts I'd probably roll them anyway just as a precaution.
Edited by danny6n
If your interested then I've got an arch roller on order that should be here before next weekend
how much for the arch roller and how does it work mate....
