1.0L Fuel Injection Pump
for a 1.0 spi 1993 polo coupe. Its not the main fuel pump its the small cylinder looking one that sits underneath car next to fuel tank behind fuel filter. i despriatly need one
thanks sam
  • Views 817
anyone
its the same as the polo 1.3 spi engine engine code aav aau years 1990-1994
ok well has anybody got one
change right your advert so its clear your advert is a little tricky to understand
title SINGLE POINT INJ feul pump required off polo 1990-1994 engine code AAV or AAU
its the MAIN feul pump you want thats located under the drivers rear wheal on the metal bracket
NOT THE LIFT PUMP that screws into the top of the tank
the feul pump off the polo GT G40 WiLLNOT work as there MULTI POINT INJ
there commen as muck have a look through polos brakeing theres loads of them :-)
