Bad back from low car?
I've had an ache in my lower back for ages now. If I bend over or do heavy lifting it really strains.
I used to put it down to playing hockey (bent over alot) and doing heavy squats at the gym.
But hockey season finished months ago so haven't been playing and not really been to the gym much lately.
sooo I'm thinking maybe my low firm suspension is the reason I've got a bad back?
hmm i dunno, any other low riders suffering :p ??
  • Replies 27
  • Views 2.9k
I've got a bad back, i tore =some liggaments in my lower back about 18 months ago and I've never fully healed. need more physio.
If I'm honest my old car (that was on its bump stops) actually used to make my back feel better.
It was on the stops at the rear and only had tiny clearance at the front.
Fully stripped out with 2 fixxed back buckets on super low fixed rails and side mounts.
being 6ft 4in i found it amaxing to be able to have the seat exactly where i wanted and be able to stretch my leg while driving.
having buckets was beautiful with the right padding, so comfy i just fely like i was being cuddled all the time and the harnesses ment i wasnt going anywhere.
ride was bouncy rather than jolty which helps alot
I could drive that thing till it ran out of fuel it was so nice
i got a bad back from cheap coilies! problems were solved with some fk highsports! id imagine even better ones would see larger improvements
my neck always hurts when I'm driving my mk2, it has rear coilies, cheap ones...
yeh mine are cheap coilovers all round, wound all the way down.
would you honestly rather be healthy than look sick? :lol:
ouch, I'm seriously considering weather i want cheap coilies now. might spend the £500+ on some with adjustiable damping
:lol::retard:
you should try running on the bumpstops with no travel whatsoever... :retard:
My back hurts all the time, have to take strong painkillers for it. That might have something to do with the 3 breaks i had in it though :lol:
Seriously though, i used to get a bit sore in the lower region before breaking it, after driving a fair bit. And that was in a 6n polo lowered right down on 600+ squid FK konigsports (damper adjust)
My back usually hurts after working on my car...because I have to bend over so far.
my gf blamed my car for her bad back but any bump in the road would almost make her hit the roof only on really bad roads
does anyone know why polos are so jarring then?
Is it tyres?
Is it the dampers?
Is it the bump stops?
or is it something else?
My last car was on the bump stops and a really tight chassis (group n mounts etc) and it always felt bouncy rather than jarring so was never an issue.
Man up. enough said.
let me tear the liggaments in your lower back and see if you still tell me to man up
:lol:
in the gt used to hit me head on the roof sometimes never had back probs tho
i suffer with a bad back, muscle spasom apparently. its only when i'm in my lowered mk loon with gt seats that i feel comfy. my mates corsa and 306 is fukin horrible ride and there standerd
My GT used to hurt my back after long periods but turning the stereo up loud enough soon cured that ;) It wasnt the jarring ride that used to bother me but the loud bangs when you hit a bump!
Nope, and i do have a back injury from playing rugby, my back felt bad when i had the saxo but not had any problems in the Polo, and with the recaro's its even more comfortable.
But i do agree with the fact you do get a bad back when working on it. :lol:
Edited by Cymro
I know how you feel with that muscle spasm thing - I used to suffer loads from it. Used to stand around a lot in clubs and that used to make it a lot worse. If you make sure you keep moving and dont stand around you'll help the muscle and it won't get pulled so badly. Also excercise to strengthen the muscles! :)
My boyfriend drives my car and says the position of my seat is a killer for him, but seeing as its at normal ride height I'll never have a problem from that.
thats all part of the fun :) till you get bumpsteer and bump braking, specially with no seatbelt, i did have a harness in mine, but i ended up with sore shoulders and hips after a 40 mile round trip :( but as above, man up and put up with it, the looks you get bouncing down the road are immense :D
Yes, but that's base spec scirocco seats for you.
my back hurt when i first filled up the car post lowerage
didnt occur to me that i would have to reach down to put juice in,didnt do the sciatica much good :-)
