Car Spraying Costs and Equipment needed?
If I buy this car tomorrow, I will defiantly be getting it painted a different colour. (Its Bright Snot Green)
I have a large double garage where it is possible to have a large area for a car to sit in and be sprayed. I have a few questions.
What equipment would I need? (This is to start from scratch ie , Rub existing down , primer and paint)
Air Compressor
3 paint guns
Mixer
Paint
Lacquer
Sandpaper / wet and dry
Well filtered mask
I was also wondering the overall start-up cost for all the equipment, Would this be around £200 - £300?
As I have no experience with this I’m assuming that that I will need to do the following:
• Clean the garage of all dust and muck in the spraying area.
• Maybe put netting up in the divide and open the other garage door for ventilation
• Take bumpers and things off
• Rub everything down
• Take lights , glass out ect
• Mask off some areas
• Make sure the body is free from any sanding dust / grit ect
• Spray about 2-3 coats of primer ?
• Spray 2-3 coats of paint ?
• Whack a ton of lacquer on and polish it?
Also , If anyone here has used a spray gun at home with a compressor , Is it hard to get it looking nice.
If possible have you guys got any pictures of cars that you have sprayed your self with a compressor and spray gun?
Pricing on the items would be VERY much appreciated as I haven’t got the foggiest. I have no idea about spraying a car other then some common since 
  • Replies 9
  • Views 1.8k
hiya mate I'm in the progress of doing mine so will try to help..here goes...
Air Compressor- I have brought a 2.5hp 50ltr compressor with grivity fed gun and other bits whitch should just about be big enough to do a pannel at a time atleast -£170
Spray guns- You can get a fairly decent one for about £20-30 prefrably gravity fed
Paint- I'm not sure what paint I'm going to use but probably 1k since 2pack is dangerous-estimate about £130 inculding primer, thinnner,paint ,pannel wipe and any other bits and bobs
Lacquer -1k dosent use lacquer as its a single stage paint however it will need colour sanding and polishing after
Sandpaper / wet and dry- lots of asorted wet & dry
Mask - i have a gerson 9000e twin canister mask - £30
Start-up cost would be nearer £400
your right with the steps
Atleast 2 coats of primer and wet sand in between coats
paint atleast 3 coats and then wet sand and polish
I'm no expert but hope that helps :D
jamie
Edited by jamiet2
you really don't need 3 guns, i've got 2, 1 for primer with a larger fluid tip on and then another for base and clear, both gravity fed hvlp (high volume, low pressure), you can get away with using a suction fed gun for primer but i wouldn't bother for base and clear and with a suction fed gun theres always chance of hitting the cup on a horizontal panel whilst painting it
you only need to guns, one thats is mainly a primer gun and the other for paint and lacquer but if you pay very little for a gun then you wont be getting a good job, i have 3 guns, one primer, one for basecoat and lacquer and small spot repair gun and these 3 came to just over £400
Thanks for all he info guys
How much paint you would recomend for a small car like a polo. I see 1L tins selling. I'm guessing il need about one as its mixxed aswell? And an extra one for work in the future?
3 litres should do the car inside and out if its staying the same colour, 4 litres to change it colour
get your paint from a body shop most paints i use need to be thined 50/50 .Pratice with spray gun first as for how much paint depends how good you are at spraying .If you buy 2 l mix them tog to match
just be aware of a few things before you start, only paint in that garage if its away from your house other peoples houses and cars as the off spray will drift onto cars an possibly into other peoples houses (been there done that). make sure your compressor is above 10 cfm, as when it loses pressure your spraying will become inconsistent an you could get runs. wet the floor before hand as this will keep dust down. use a proper spray paint 2k mask at all times. 2k although more toxic is easier to paint. if your not changing the colour just paint the outside. 3 litres of base an the same in laquer will be enough. you want to be painting over no less than 600 grade wet and dry. an before you start on your car, get some scrap panels an practise practise practise!!!
Unless you painting it metalic, you wont need laquer at all. Also, one gun is sufficient as long as its cleaned well after use.
I went to get all the stuff for an engine bay spray, and it cost around 100 notes. Panel wipe is an essential too. otherwise, its mostly been covered. I wouldnt bank on anything less than 500 quid at the least, especially if you're doing the inside too. There will always be more costs than you originally think
check the paint before as i use self shine acrylic, which dosent need laquer, also rub down with lots of wet and dry to make sure paint sticks, and also to get rid of clumpy primer or paint aswell, rub down with a normal clothe or rag, or blow off all remaining dust and excess form sanding. then paint.
