Dewiper question!
Ok so I'm anni v on dewiperin now as I'm gonna be bored tomorrow after work and the only draw back I can imagie is the washer pipe leaking in my boot! Seen as tho I have a boot popper (2 wire central locking solenoid) and a 5 wire central locking motor in there I don't wan any water anywhere near it! Also hav amp sub etc in boot so I was thinking......can I block the rear wiper pipe anywhere else under the bonnet?
I have even thought about putting a t piece in somewhere and running the rear pipe to it so now matter which way I push the stalk it sprays out the front?
Any suggestions or have you blocked the rear washer pipe at a location under the bonnet?
  • Replies 15
  • Views 1.8k
think it runs along the top of the passenger strut. best bet i found is take off the trim in the passenger footwell next to the sill and undo the washer pipe there. trace it under the dash and just keep yanking till it comes out.
sweeeet! how about blocking the bugger off/returning it to the front jets? once I've found it???
Personally, i've dewipered 5 cars in total now. 4 of them being polos....
either, completely remove the hose. (cut the end in the boot, make sure it's not cought on anything....an give it a pull from in the engine bay. it'll feed it's self out no problems.
OR, wadge some heavy duty glue into the end an secure the pipe so it wont rattle around.
either way, it won't be leaking. :thumbsup:
thats what i did to the vac pipe for the C/L in the boot, super glue then a screw of the right size and had no leaks.
I dont think youll have an easy job pulling the entire hose out as its taped to the loom in lots of places throughout the car
what you wanna do is what a load of us used to do on the pugs and run some poly tube (wickes/homebase B+Q etc) to the front of the car then stick the nib casing off a biro into it and mount at the front of the car so you can squirt mopeds
Edited by Dum-Dum
I could pipe it up to some newer vag washer jets n mount them under the front arches make it look like I'm running a really wet nitrous system haha! Fake nos purge ftw!!!
My mate in his lupo had his rear wiper jet re-routed to the badge on the front grill and use to soak people with it at traffic lights, he use more water wetting people than cleening his windows :lol:
i stuck a grub screw in mine folded and cable tied...no leaks and why would it leak theres no need for you to push the re-wiper stick back anymore
Just incase I do push it back accidently and something gives! Lol
Edited by Pepe
Loool! Sooo want to do that now =)
and in my old mk3 i just shoved a screw in the pipe at the boot end, never had any leaks =)
See the motor on the water tank,it should have two pipes to it. Find which is front and back,and cut the back one. No more water to the back,no need to pull the pipe out,can just leave it cut back tidy.
As for the cut bit of pipe sticking out the motor,yes you can aim it at people but you could also link it to headlight washers..
Or test out the wiring to the pump, find which is the switchwire for the rear wash, then reroute this to your boot popper solenoid via a relay on your open door switch (the swich that turns your interior light on when your door is open) This way you won't have water coming out of your rear washer pipe, you have a neat way to open your boot and you don't have the danger of inadvertantly opening your boot while driving as it will only work when your door is open.
Good idea that danny don't suppose you know were Id find that wire? I can probably splice into my alarm wires on that door switch aswell but I CBA to re wire all the shit just yet haha
oh and is it MOT ok if I just unplug all the wiper and tape/tie wrap it away somewhere?
Edited by Pepe
Yeah I wouldn't be arsed doing it, but it would work if someone could be arsed. I'd assume so, nothing in mot about needing rear wash/wipe.
Just go to a scrapyard and get a pump off a car that doesn't have a bidet (Polo Saloon, Vento, Passat). Old Vauxhall pump is the same fitment, so that also adds Omega, Carlton, Vectra Saloon, Corsa Combo van.
take the pipe off the bottom of washer bottle (remove the 2 10mm headed bolts to make life easier) then if you do accidently touch the rear washer it will jus dribble onto floor behind arch liner. also then the pipes there if you ever want to refit a wiper.
