mk 3 rust?
off to go look at some mk3's this weekend and wondering were should i be looking for rust on either breadvan or coupe if there's any differences
Also if there's any other major issues i should be looking for thanks :)
battery tray
underneith the front the footwell. look for a hole. engine bay on the front panel to.
Battery tray seems the most common.
I've got some on the rear edge of the front arches so have a look there too.
The front of the right hand rear arch, infront of the tank neck. All the rust you can see is hidden by the neck, the horizontal metal pipe you can see usually disintegrates.
alot of mk3s i've seen leak like a sieve by the sunroof and then rust all the water channels ect which can lead to ENDLESS MISERY!
