AFH Bike Carb Conversion Kit
I'm selling the full kit you need to convert an AFH to bike carbs. This includes:
cbr600 carbs
air filters
facet fuel pump
throttle cable
throttle adjuster linkage
weber throttle pedal block
mk2 vacuum advance distributor
mk2 coil
mk2 ignition amp
mk2 ignition wiring loom
afh inlet manifold
this lot owes me just over £300, so am looking for £230 collected. can deliver at cost. cheers
  • Replies 23
  • Views 1.2k
any interest?
Has this been set up already (jets etc) i.e. could I just bolt everything on and it would work?
they could do with being jetted to suit your car once everything is bolted together to get it 100%. they are jetted with 135 on the outside jets and 138 on the main jets iirc. i know saf has been running cbr600 carbs on his afh mk2 for a couple of months on standard jetting with no problems though.
even if they were jetted for tez's engine, they would ideally need setting up on your particular engine, two identical engines will most likely need the carbs fettling with even if they were running absolutely spot on, on one of the engines
and 230 collected is cheap considering the sum of the component parts, the inlet manifold is one of the best homebrews, designed using the original afh inlet manifold flange, so is perfectly port matched on the inlet side, and perfectly spaced for cbr600 carbs. it was the prototype i used to supply my engine builder with to produce the items in stainless steel for the group buy
cbr600 carbs - 40 to 80 quid 2nd hand
air filters - 60 quid for a set of 4 new
facet fuel pump - 25 quid new
throttle cable - 10 quid new
throttle adjuster linkage - 2.99 new
weber throttle pedal block - 12.99 new
50 quid for below
mk2 coil
mk2 ignition amp
afh inlet manifold - 130 quid in group buy
cheers saf :) yeah its a good manifold design. the carbs go on perfectly and fit nice and snug.
this may sound dum but i have a polo 6n 16v.
what are the advantages over the standard throttle body?
More power and an awesome sound basically. Max_crox got about 126bhp on the rollers with a carb setup
hmmmmmm very tempted :)
ill let you know
no worries mate, just pm me if you're interested. a courier shouldn't cost too much anyway.
Swap and cash your way for a BMC with all the bends in blue hoses??
24328_371797804197_700029197_3552881_230
Say £80 your way??
Edited by Boss
hi mate how much for the full set up and would all of this fit on a mk2 engine ? thanks
hey mate, its 230 for the setup. its for AFH engines, which is the 1.4 16v found in the polo 6n, so unless youve put one in your mk2 then no it wont fit.
cheers
Why you selling Tez? Whats it like on fuel compared to a standard valver BTW?
I'm selling because the polo is gonna be on its way soon. Got my eye on a nice e30 :)
fuel consumption depends how heavy your right foot is :D same as normal really haha
SOLD
what are they like on fuel?
i just worked it out that on 15 quids worth of super i got 112 miles which works out at 42mpg ;)
alright for some. i got 80 miles to 16l of v-power last week :lol: 22mpg of fury
trip to bogg brothers needed methinks
Edited by tezmc
definatly dude! much needed.
you selling your wheels btw, i might have them if you are
if I can get my hands on the ones I want, then yeah they'll be going. Will let you know =]
I need to sort my rev counter as well. It goes well at the top end but I'm scared of blowing the thing up haha.
hy tenzc can i ask you how you minimize the presure of fuel.tnx mate
thats well good! thats better than what my car is doing now. aha.
what is the power difference like?
and what sort of bhp gain is there too?
cheers
Edited by stefan edge
