mk3 breadvan side strips?
i want to get rid of the side strips on my breadvan
just want to know how to go about it?
How are they held on?
Thanks matt
they're sticky taped on from new , best warm em with a heat gun and peel off
then there maybe sticky left on the paint...use white spirit or something on a rag to soak it and peel off
If you prise one end up, the one at the edge of a panel is best, they should peel off with little effort. After, peel the tape off, then use a fudge/toffee wheel to remove the glue residue. Its a hell of a lot quicker than thinners and rags, and costs about a tenner too!
Then i recomend cutting the paint back (with g3 or similar, not T-cut) around the area and then polish it up.
There is a sticky somewhere in this section
I would definatly reccomend a toffee wheel
