water in car?
couple of months ago my mate put his seat belt on and it was soaking wet - i didnt take much notice. the other day i noticed that behind the passenger seat on the floor it was all wet and a pile up of water under the matt.
whats the cause for this problem and how can it be fixed??
iv noticed it happens alot on rs turbo's - have i got a leak or hole underneath the car??
any advice on this peeps :roll:
Edited by koolspot
  • Views 1.2k
If its on the floor, try taking a peak under the carpet and make sure theres no holes in the floor.
Though you say it was on the seatbelt before as well - try checking the door seal round the passenger door.
nice1 goose...
i had water build upin the boot but now seems to be going under the carpet behind passenger seat
got exactly the same problem, i get puddles in my boot and the bottom of my rear bench is always wet
i had this exact problem with my mk3 it turned out to be the door seal on passingers side. i also had leaks on the drivers foot well and in the rear too. it didn't take me long to realise that my battery tray was acually duck tape over a huge rusted hole. lol i'll have to get a pic its pretty bad.
also i noticed when i welded my battery tray there was a peice of sealent on the passangers side just under the fuse box. this lead me to belive that it had been sealed once already. the problem to all this is the drain holes located in the wing. these are designed to let any rain water that comes trough the bonnet to drain away.
when the leaves start to fall in autum they can also end up under the bonnet, and end up blocking the drain hole so everything sits in warter with no where for it to go so it sits there eating a hole in your car.
i'd check to see if you have any sealent in that area around your fuse box mate, and check that your drain holes are clear of s^&$ !!!.
This could also be the case for your seat belt... when the sun comes out and is mangified by the glass in causes water to evaporate, however your car being sealed up it has no where to go and so when the tempreture falls it candesates in all the fabric (roof linings, seats and seat belts etc) its a fuck^&* nightmare !!
although i cant say anything about the boot but i emagine its something pretty similar but can't say for sure
Sorry about the spelling :-)
