Window Tints - Removing Them?
OK, car has had really dark tints on the back windows and slightly less dark on the door windows. They've been there since I got the car and I want rid. I don't really like them and the wife (and baby!) were followed by the po po today, presumably because they thought a little slammed Polo with black windows might be up to no good so thats the last straw...
So, how do I remove them? Know nothing about them so I assume its a film on the inside of the windows. Whats the best way to remove? They're not going to be a proper pain in the ass like wallpaper and come off in the smallest strips known to man and take me months to remove?! Anything that will help it come off (like Nitromors for window tints :lol: )?
Cheers all,
Dave
  • Replies 9
  • Views 1.7k
i got the tug from plod over tints in a car and had to remove the fronts,were already fitted before i used the vehicle
it was like wallpaper,used petrol in the end to remove the adhesive,took a day to shift it
you may be more lucky :-)
hello mate..i worked for a tinting company before and this is what i did on most vehicles :
1. take the door cards off
2. using plastic sheeting cut the plastic to the same shape as the windows
3. on the inside spray the window with soapy water...use alot of water
4. place the plastic over the window covered in soapy water
5. place an electric heater inside of the car, make sure all windows are covered and soaked with soapy water
6. leave for about 2 hours, the longer the better.
7. using a heatgun - heat up the windows from the outside. do one window at a time, once you have done one window do step 8
8. while window is hot, slowly peel the tint off.
now it is possible that some cheap films to leave alot of glue behind so what i find easy is to use a stronge glass cleaner alt you can use white spirit or petrol but please allow plenty of ventilation. spray the window and using a sharp straight blade scrape away glue. it should turn into a pulp.
this is not a quick process esp if its your first time you might get frustrated. there are decent tinting companies out there that will remove them for you - just dont get ripped off !!
hope this helps mate...
the law at the moment states that your not allowed no tints on the front 2 doors but you can have whatever you want on the rears.
cheers
Cheers guys. Just wondering, roughly how much did you charge to remove tints? Just so I have a (very) rough idea as it looks like its a decent job so I'm guessing be a major ballache for me to remove.
mate its really easy. you dont even need to do that mentioned above...
I'm a valeter hand have had to de tint a bad ass corsa before lol..
i literally made a nick in the film with a blade enough to peel down a bit.... gentle heat from a gun will help ease the film back..... you will be left with glue..... but spray with Tar n glue remover and leave to soak for a couple mins then spray again and scrape off with blade. then clean your glass with usuall glass polish or whatever u use and jobs a good un
took me like 20 mins to do the rear
let us know how u get on
Cheers mate. That sounds more like it. So the film is always on the inside of the window?
yeh mate always on the inside. unless its a chaved up saxo then could possibly be on the outside with a 10 inch exhaust to match... :) any probs give me a shout
Checked and deffo on the inside. Maybe make a start next weekend... Progress update to follow!
sorted mate!! its reallly easy once u get going. just annoying scraping the residue of lol!!
Right, film is off - dead easy. Now the glue! Did about 1sq ft of the rear window yesterday and it took half an hour! Going to get biblical on it with tar remover/white spirits ASAP! Looks loads better though!
Cheers for the advise fellas!
