Shadow Grey 6n 20vt - FOR SALE
DubbPrince, you are THE fucking don tbh.... Well worth sending you the polo wiring loom and a TT loom and pay you moneyz to make fix! :lol:
So close josh, so close man! bet you cant wait :D
Much more you want to do after the engine is in and running like?
  • Replies 264
  • Views 46k
  • anyone think the wiring colours will be different from the APY engine and the BAM ? can only find wiring diagram for APY engine if they're the same heres what I've got... tell me if you think this
  • Guest POLOMON
    Guest POLOMON
    winner winner, chicken dinnooooooor
  • finally the cage has arrived ! although on the laser etched plate custom cages have supplied they've spelt Volkswagen wrong useless. In the pictures the harness bar and door bars (don't know if ill
I'm literally soooo excited :lol:
got a new radiator and front cross member to pick up tomorrow, then get all the front put back together.
run some cheapo oil through it seen as its been stood like 10 months, then put some decent stuff in, attach header tank, wash bottle and a few other bits in the bay
need to buy an air filter for it yet...
needs tyres too
then its just little things, wheel alignment, getting it set up properly
first things first though, actually get the accelerator pedal to work :lol:
accelerator pedal... fuck off wiring, use cable... done :lol:
Well if thats all you have to do be done by the weekend :-) :lol:
cheers sanj ! ill check that out tonight..
not having that wire connected shouldnt have any effect on the pedal though should it :/
so now I've no idea why thats not working :(
that means swapping over the pedal box, i think ill stick with my wiring for now haha
heres what I'm dealing with on my pedal...
basically i just need a wiring magician (Sanj) to help me :lol:
AUDI
POLO
Shouldnt do...i need to verify this is the wire though, without checking your ODB2 diagnostic port, i cant confirm...
As for the pedal wires...you should have:
T10h Blue connector
pin 1 - brown/white to brown/blue ecu T121/34 to throttle sender T6b/6
pin 2 - green/white to green white ecu T121/72 to throttle sender T6b/1
pin 3 - yellow/green to yellow/green ecu T121/73 to throttle sender T6b/2
pin 4 - grey/red to grey/red ecu T121/36 to throttle sender T6b/3
pin 5 - white/blue to white/blue ecu T121/35 to throttle sender T6b/4
pin 6 - grey/blue to grey/blue ecu T121/33 to throttle sender T6b/5
Then on the opposite end...you would have the pedal connector on the interior loom of the golf mk4/TT etc...Its a bit backwards. On the Polo GTI, the bay loom has the throttle pedal connector coming straight from the ECU and straight to the pedal but on the TT it goes from the ECU to a blue connector and then on the opposite side, a blue interior loom connector hooks up to the fusebox and on the other end of that is the throttle connector...long winded!
Above is the pins for ECU to fusebox connector...
Not sure how yours was wired but me, i've De-pinned the Polo GTI loom and seperated this throttle connector wiring as i plan to re-pin it onto the TT ECU wiring...so straight connection...
honestly mate your an absolute life saver ! ill try this out tonight and report back if all is well !
beer tokens are definitely owed for all the help !
So glad I'm using the cable throttle... i think Harry would agree with me too.
Definitely!
P.S. Do any of us actually do any work at work? Lol
its all about cruise control boyo :)
Your months off worrying about that anyway :x:lol:
Cant remember the last time i did...oh yesterday i changed a belt on a tacho? :lol:
In the famous words of Liam Neeson...I will find you...and i will kill you.
ahhaha...hell no, perks of the job. 8-)
8-)
my work is split between here, edition, drag racer v3 (that was todays game anyway) nad answering a few technical questions on the phone
EEEEAASSSSYYYY
8-)
8-) winner winner, chicken dinnooooooor
also just seen that your 2's threads had 5 star ratings and mine had none...
just rated myself 5 stars :paranoid::lol:
sorted that for you.....
wheeyyyy !
2 ratings of 5 star perfection
Hopefully this helps you out dude...took me a few mins, but here goes:
complicated TT version (below is ECU to male fuse box connector) stage 1:
PIN 72 on ECU (green/white) to PIN 2 on blue connector-
PIN 33 on ECU (grey/blue) to PIN 6 on blue connector-
PIN 34 on ECU (brown/white) to PIN 1 on blue connector-
PIN 35 on ECU (white/blue) to PIN 5 on blue connector-
PIN 36 on ECU (grey/red) to PIN 4 on blue connector-
PIN 73 on ECU (yellow/green) to PIN 3 on blue connector-
Now to go from the female fuse box connector to 6 pin throttle pedal connector stage 2/3-
PIN 1 brown/white becomes brown/blue on blue female connector- to PIN 6
PIN 2 green/white becomes white/blue on blue connector- to PIN 1
PIN 3 yellow/green stays yellow/green on blue connector- to PIN 2
PIN 4 grey/red stays grey/red on blue connector- to PIN 3
PIN 5 white/blue becomes grey/blue on blue connector- to PIN 4
PIN 6 grey/blue becomes grey/white on blue connector- to PIN 5
So what i've shown you above is basically this in pictures:
ECU to fusebox connector:
Then from there to the interior loom:
And from there to this (ignore that it has a blue connector):
Edited by DubbPrince
AAHHHHH We've got revs !!!!
SANJ YOU LEGEND !!!
honestly though mate, thanks soo much for all the help ! i owe you big time !
WHEEEYYYY
WHO DA MAN!?
...Sanj Da Man ;)
and me too :(
I'm happy its the only bit i struggled with tbh
sooo excited now !
and me too :(
sooo excited now !
Haa...no worries lads. Glad you got it sorted, any other issues...stick them up. You should be mobile now right? 8-)
