'2G0' 1989 Polo Saloon Parts
Hi All,
My brother's just bought himself a lovely 1989 Polo Saloon, engine code is apparently '2G0', 1300 5 speed
The oil pressure sensor is leaking, I rang Cambridge VW who said even though the reg brings back the VIN, model etc, they arent able to tell which oil pressure switch they should supply me with. Apparently there are 3 types which all read a different pressure bar
Any ideas where i might be able to get an equivalent engine code so they're able to find the part, or even the correct part number? I've looked in the parts section but there's no mention of it
Any help would be muchly appreciated
Ash
  • Replies 8
  • Views 1.4k
If you unscrew the oil pressure sensor from the head, I think it might have a reading value stamped on it? CAn someone else confirm this as I can't remember. Also will have a VW part number on it, if you can get that then ETKA can be checked to see which sensor it is..
Try this website, its a list of all the parts VAG ever made-
www.vagcat.com
Search for your loon there and then the required part.
correct.
Crikey, i've never seen so many replies in such a short space of time! :shock:
Cheers for all the help guys
This is what it's coming back with;
7 028919081D 028919081D
oil pressure switch / 0,25BAR M10X1 oil pressure switch / 0,25 BAR M10X1
/ 1 pin / 1 pin
/ blue / Blue
(7) (7) 056919081E 056919081E
oil pressure switch / 1,8BAR M10X1 oil pressure switch / 1,8 BAR M10X1
/ 1 pin / 1 pin
/ white / White
(7) (7) 068919081 068919081
oil pressure switch / 1,4BAR M10X1 oil pressure switch / 1,4 BAR M10X1
/ 1 pin / 1 pin
/ black / Black
We've taken the switch off and there's no part number or pressure rating written on it unfortunately :-( Maybe it's been changed for an aftermarket jobby meaning it's not got the VAG part number on it?
Where it states colour in the info above, what does this refer to? The plastic part of the unit is black, would that mean I need the 1.4bar version, or is that too logical? :lol:
Cheers guys!
Ash
Nice one mate!....on the google link :thumbsup:
hehe no problem, thought it might help people.
@OP, I'm not sure, why not try the black unit and see? :p If they're not too expensive.. GSF should stock them.
