bump strips on the sides of 6n
do the bump strips on the sides of the polo 6n just peel off or are they held on in any way ?
  • Views 754
Peel off, but be careful not to pull paint away as well. Use hot water and a credit card of sort to get the glue off. Or you could buy something called a "caramel wheel"..google it :p
NO they dont just peel off...they are glued on with an adhesive...you need to heat it up with a hair dryer or heat gun and gently prise them away.....if you used the search function you would get loads of results
