16v bottom end/ gti head!
can this be done/ has it been done and would it make much difference?? aaron
  • Views 1.4k
isnt it better to do it the other way round surely? eg gti bottom end then afh top end??
i dont no m8, just want to do something else to my car!!
higgo's right, its better to do it the other way round :thumbsup:
do a search mikeymks said everything u wanna know
I cant copy and paste the link,but the topic is called 'AFH head wit GTi block' and the reason for it is to create a 1.6 version of the 1.4 16v AFH.
The whole point of doing it is because the AFH head is arguably the best cylinder head ever made for the short block engine,unless you're into your variable valve timing. It has the biggest set of ports (exhaust) of any other at all,and whilst its older design isn't as smooth as the later roller-rocker design,it has sporty cams for factory items and seperate cam sprockets for those wanting to use verniers.
Most importantly to most doing this,it takes a distributor with no modification. The later head will take a dizzy,but it needs some high quality doctoring.
Mikey your a hero, now I just need to go find this topic and read it over and over and over
