6n2 GTi Cams, Manifold etc....
Right basically, these questions may have been asked a LOAD of times but i'm going to ask them again lol
Going to use my polo as a track toy and buy a bora tdi as a daily and to trailer it about after christmas time, in the meantime while the polo is still my daily, i'm going to be buying some goodies for it.
Want a fast road set up, basically a set of mild cams, decent manifold, will be getting lower front strut brace for it too, its already on a cheap set of coilies, but if all goes well next year will look into a set of Gaz or KW
Would like some G60's but for the minute while am getting used to the car want to upgrade the standard size ones for the likes of EBC discs and some red stuff pads, some lightweight wheels such as team dynamics pro race 1.2's or some comp MO's with some 888's.
want to know what experience people have had with different cams, manifolds, are the likes of whiteline anti roll bars available for the rear or them? and also where the best place is for a cage and any other track car related bits
thanks for the help
Gaz
  • Replies 10
  • Views 7.6k
and the best places to use as there dosent seemto be that many people selling the bits cheers
47 views and no replys sure someone can shed some light
hey man! good to hear that you have got a good state of mind for your polo ;)
I was also curious about getting cams for my car.
From what i have been told, this is a very difficult and expensive thing to do with this engine.
Apparently, there the head operates with rockerarms (to deal with higher RPM's).
Also, dont try to look in there yourself. It is not exactly possible to take the cam-cover off like on other normal polo's.
I managed to get a good cage made very well for about 450 euro. The company made it by hand, and they were very professional, and friendly.
Pleie sport i believe they are called.
If you take a look at my build thread, you can see what it is like to install and how it looks, etc.
I can highly recommend getting rid of everything that you dont need:
carpets, roof lining, rear bench, sound deadening, middle damper, air conditioning, cruise control, door cards and both of your cat's. (you will need a custom downpipe or a nice set of headers).
As far as headers go, I have also been told that 1.4 16v headers will fit on the GTI as well.
hope this has helped a little!
any other info? there must be at least one person on here with a stainless manifold on their 6n2 gti
grab a stainless 4 branch for a 1.4 16v AFH the bolt pattern and port spacing is the same, albeit the larger exhaust ports on the AFH head, but this will be advantageous for more breathing on your 6n2.
I've just sold a lupo gti head to KamRacing over on club lupo who is sending it over to a cam builder so prototype some differnt cams for charged adn itb'd arc/avy lumps
worth dropping him a message
Edited by grungeisdead
sounds good to me, so an AFH manifold will bolt straight on no bother?
AFH manifold does fit but it has EGR take off on the side, i cut mine off and welded it up, also i cut off the warm air take off (personal preference realy) I'm intrested in cams too, but spoke to schrick and they need your old cams first to compare them as theres apparently 6 types! and ther soooo exspensive!
heres my AFH manifold on GTI engine
That carbon engine cover is awesome. Tidies up the bay nicely.
I'm pretty sure with the GTi you can just bang on a set of G60 carriers and use the standard calipers to make them 280mm. If your gonna be replacing the discs and pads anyway might as well get a set of G60 carriers and upgrade them to 280mm.
cheers, its for a 1.4 16, but with 2 seconds of trimming it fits a GTi, ands as said G60 upgrade is by far the cheapest/easiest brake upgrade fo a GTi, I've got them and cant fault them
Just sent a PM on here aboput some G60 brakes so should be mine a.s.a.p
is your strut brace a cheap ebay jobbie? i've seenthe cheap ones but i'm a little bit weary of them, there for a 6n too so need to know if they will fit my 6n2?
i will be getting a 1.4 16V stainless manifold and will geta local guy to weld the EGR and hot air take off on it, good ol' pipewerx :-D
Any one running a front lower strut brace as thats the main brace i'm after, made so much difference to the zetec-s i had felt so much more point and go :D
cheers for the replies!!
