Washer pump on S Reg Polo
Can anyone help with some info on the pipes connected to the washer pump on my S Reg Polo please? There are two rubber pipes connected to it. I take it the left hand pipe runs to the front washers and the right hand one should run to the rear washer?? On mine the right hand pipe is only a few inches long and when I push the stalk forward, which should work the rear washer, fluid just pumps out of the short pipe. Has this become disconnected or is this just some sort of overflow meaning the rear washer is blocked?
Wayne
  • Views 733
It's probably popped out mate. Try finding the other pipe and it should just push back in.
Thanks, thats all it was and the dealership wanted to charge for a new pump!!!
Wayne
