ohhh what to do?
well my mk2 loon has just destroyed its 2nd drive side inner CV joint within a few weeks, so i have been advised to swap the box and shafts for good measure in-case something else is causing it to eat the shafts.
but the question is:
A - do i replace the gearbox and shafts and keep using it as it is?
orrr
B - bite the bullet and do the 1.4 valver conversion with bike carbs?
i know theres a huge difference in how long the jobs will take and difficulty, but either way its going to be off the road for some time anyway while i source a box etc and tbh i have been considering the engine swap anway
but also money is an issue for the next few weeks until i get paid and after reading the conversion guide my dad thinks it could get very costly, is this so??
thoughts please??
craig
  • Replies 14
  • Views 2.2k
anyone?
ime in need of guidance :)
Edited by pugownerbilco
well it depends how much u wanna spend i have a 1.4 16v and was thinking bout doing the bike carb conversion and i was offered a full bike set up for £230 quid so if u add tht to what a 16v engine cost so i would say you are looking at aroun the 400 quid mark ten on top of tht u gotta get it running properly and I'm not sure on what tht would cost it all depends on you are wallet really
that's a good price but if you were to buy all the stuff separate it would work out to a lot more than that, i think the manifolds are not far off that sort of price from bogg brothers.
well i have been discussing with various people and friends today, plus after a bit of an accident in the garden while manoeuvring the car out of the way (involving my front bumper and the house!) i have decided to go for the engine conversion as it would seem the best decision right now as i have another car i can use instead now :)
so watch this space :p
bigger brakes required
gt brakes good enough? not bigger i know, but vented
GT brakes arnt vented, its G40 ones that are
Could just go for a cheaper, more simple GT on bikecarbs conversion? Cost half the price and take a 3rd of the time.
And yeh, u want VW2 brakes.
ahh sorry thats what i meant :)
but a valver on bike carbs is more power :p
It is yes. i agree
But if you say money might be a problem then clearly it isn't the answer.
16V into a MK3 is more work than some people seem to think it is. If you have access to machining equipment etc its easier. but if you don't it costs and takes time.
GT on bikecarbs, will cost around £400 if you can get stuff cheap, £500 if you need some stuff new.
Valver on bikecarbs, £700-£800?
The 1.4 8v ABD is a straight swap,a third the cost of an AFH,and it runs very well indeed on bike carbs. Posh manifolds can be expensive,but they can also be knocked up in steel for peanuts - and i dont even use one.
You're looking at £300 maximum if your car's a MK2 - and that's running.
That depends on what you can do yourself.
If you have to get the inlet made up thats nearly £200 alone. then bikecarbs (about £60 off eBay)
I'm Bias though when it comes to Gt vs 16v conversions. I'm gunna be spending silly money on my GT conversion when it comes to fitting the bike carbs etc. I'm not stopping till i have 100 at the wheels. But looking at it all i cant see it being that difficult. (abd bottom end, high lift cam, bikecarbs, headwork, gt box, stainloess system and so on)
the 16v only involves modifying one engine mount though if i am correct? and i have read the guide on here for the conversion and theres alot to it but there doesn't seem to be anything too challenging from what i can see, although you are the guys who know more than i, so ime all ears :)
and yes it is a mk2
oh btw i did see your way of knocking up an inlet and ime very intrigued, any chance of some more pics and info please??
