How to remove rear bumper ?
I'm going to be removing my rear bumper next week and woould just like a heads up on what to do before i break something ? If your going to do something, do it properly =]
  • Views 1.2k
lots of 10mm bolts, about 4 under little plastic covers at the top, and a load at the bottom
the bottom ones sometimes rust on i had to kick mine off and snapped my exhaust hanger off with it. dont do that.
thats the easiest part of the car after the front grill to take off there are 4 bolts under the plastic caps when you open the boot and 5 underneath the ones underneath you nay need a set of mole grips for as the rust real bad and the socket usualy rounds them
thanks for the info guys ill let you know how it goes =]
