common faults on early mk2's?
i feel like i'm going to regret the moment i started this topic, but i'm hoping the list won't be too long...
the only fault on my car at the moment is that the door seals are knackered...
does anyone know the common faults i should keep an eye out for?
x
Edited by dachma'84
  • Replies 15
  • Views 2.2k
rust and fuel tanks and erm rust
Rust
especially in the battery tray, if you take your wings off, clean all the cack out of the drainage hole, might help avoid this :)
Brake calipers are dire on pre-'86 cars,id class every one as faulty just because they're that rubbish. Later ones are a straight swap. Brake pipes rot,though they usually fail an MoT before they fail.
Also,the earlier steering column is joined at the safety break-away point with two small rubber bushes. These wear and perish,causing numb/vague steering. I dont know if replacements are available but I'm using the far better telescopic column,as fitted to later MK2/F's.
Pierburg carbs can be a bit of a bugger at cold starts. With Mk2s I've owned I found having the proper hot air ducting from the manifold shoud to the air filtre made a HUGE difference! :-)
Well, the battery tray is solid, theres a small amount of rot on her and i haven't had a chance to check the filler neck yet.. and she's running a webber already...
Why upgrade to the later spec brakes? whats the differece?
Edited by dachma'84
Before '86 they were fitted with partially pressed steel calipers,which held tiny brake pads. These arguably were never sufficient - even a quarter century ago when they were discontinued,let alone on today's roads.
They were replaced with cast iron VWI calipers,which use considerably bigger pads.
An additional upgrade is the VWII calipers,which allow vented discs,but these are not generally necessary for a standard model.
yep I'm an advocate of the postage stamp brakes can kiss my ass.
cause of my lil front end shunt! upgraded to the brakes off my mk1 golf gti and its been hunky dory ever since, even after the power output has gone up over 110%.
before i used to get brown trouser moments if i ever needed to stop at any speed!
mikey - never new that about the steering column, i will have to investigate mine, as my front end is solid but i have an unnerving wheel wobble that I'm still yet to place my finger on, replacing the steerng rack and column, or examining the structural integrity of the UJ was my next port of call
Are the mk1 gti's the same as the 256mm vented on the mk2s?
Edited by dachma'84
no 239mm - mk2s have a different hub spacing so will not bolt up to a mk1 golf or mk1-3 polo
are they easy to get hold of?
Edited by dachma'84
yes very easy get over to the vw mk1 golf owners club, calipers can be had for about 20 quid, or you can grab vw2 calipers over lots of different models in the vag range, and you need some carriers from a late mk2 or mk3 polo (to suit the mk1 golf / mk1-3 polo hub carrier spacing 76mm iirc)
oh also on the early mk2s, they have a contact breaker based ignition, often referred to as 'points' ignition. you can get a new contact breaker for about 5 quid from GSF and you set them with a feeler blade, it'll wear over time and need replacing.
the alternative is the later mk2 igntion setup which is electronic with a hall sender in lieu of a contact breaker, and the inclusion of an ignition amp.
depending on your engine and cam drive, you may need an mk1 seat ibiza dizzy, or you can swap the cam drives i believe from the early dizzy, to the later electronic dizzy
poo berg carbs suck ass.
it is worth getting a webber.
Also the location of the fuel filter, can be known to heat up and leak as it is right near the engine. Mine caught on fire due to this :/
is it worth trying to fit a brake servo offa later polo?
it can be done, see katmk2polos thread, but its not simple, you could fit a remote servo if you dont mind about the install looking factory!
poobergs arent shit tbh its just through lack of maintainance, a well serviced poopberg should out-perform a weber in terms of economy any day fo the week
