New Polo with a central locking /alarm problem!
hi, joined the forum hoping you can help! not sure where to put this, so please move if it is in wrong place!
I recently purchased a 2001 polo gti privately, it only came with one key. the key starts car and manually opens car fine, but does not work as a remote key.
the red light on light on the key flashes but it doesn't unlock the car. also when we manually open drivers door with key, the little red light by the door pin still flashes and if you dont start the car within in a certain time, the alarm goes off! when the engine is started, the light stops flashing.
Is this problem an easy fix? is it something thats fixable and can be sorted out? how much would it cost roughly?
any help, suggestions or ideas are greatly appreciated, as you can imagine it is very annoying!
thanks
:paranoid:
Edited by Chubbs_GTi
  • Replies 10
  • Views 1.8k
Have you tried the whole turn the key in the ignition and press the open doors button (i think thats how you do it)
it sometimes resets the key to your car.
Don't quote me on that though.
tried something like that and it didnt work. are there any other methods?
replace the key battery, it's flat :)
if it was flat surely the little red light on key wouldnt work?
The key has 2 different parts; there is a passive immobiliser and a remote part. The passive immobiliser is a small chip in the key which talks to the door locks. That bit is obviously working fine as you can start the car OK. The remote part is a battery powered RF transmitter which operates the central locking and alarm. The passive bit is matched with your specific car and only a VW dealer can do this. The RF part will work with any car that has 'learnt' the code; you can do this bit yourself.
It's possible the car has lost track of the code for the remote part of the key. I'm not sure how to do it on a Polo, but check your handbook (if it came with one) and there should be details of how to match a key to the car. You can have something like 4 remote keys to a car for VWs.
I had an Ibiza where the RF part of the key had completely failed (LED came on but no signal). I got a second hand key off Ebay (must be exactly the same model/year etc.), removed the RF transmitter part and put it into my own key with the original passive part. I then matched the car to the RF using the handbook instructions. Worked fine, and no need to get the dealer to recode anything. You could just get another key and use it as a separate remote if you don't want to risk your only working key!
In summary:
First thing to do is replace the battery.
If that doesn't work, match the remote to the car using the handbook instructions.
If that doesn't work, you need to repair or replace the key.
(There is also a very small possibility it's a problem with the receiver unit in the car itself)
It may be the battery is tired and the signal is too weak even if the LED comes on.
thanks for the reply :) but i have looked in the handbook and it doesnt really say how to do it?
:( anyone?
iirc the blade comes off with the plastic semi circle, then the two parts split.
yeah thats right :)
but I've tried searching and can't find anything saying a defient step by step to "learn the key"
