How do u jack up ur realy low polos
Just wondering how yo jack up you are realy slamed polo do u park half the car on the curb and then jack it up :ninja: or is there a jack for lowerd cars ???lol
  • Replies 16
  • Views 2.3k
You can get low-lift jacks, but personally i just drive up a couple of slabs :lol:
Yep slabs or blocks of wood drive on and then jack up! Low profile jack will make the job easy as pie!
pump some iron and lift the fucker
we use wooden blocks and then get the scissor jack under, then get the trolley jack once it high enough.
Tis a pain in the arse lol
drive onto a bloch of wood, then a brick then a stack of bricks (two high) then wang the jack under. Or reverse one wheel up the sloped bit of a dropped kerb then jack it on the rear axle.
Looks like block of wood ftw :)
Good old blocks of wood tbh ;)
i just lift the car by the wheelarch and slide the trolley jack under with my foot.
if you have loads of money then a low profile jack would be the obvious solution. another trick would be to use a sissor jack untill its high enough to get a trolley jack under it
I've tried to get a low trolley jack under mine, didnt happen.....
blocks of wood, standard vw jack, then the trolley jack :)
great minds think alike only mines that much of a tw@t i usually end up getin some1 else to lift lol
The scissor jack you get with yor car use that to get it high enough to fit the trolly jack in
I have a flat kerb on my drive (seen just in front of the Polo),so even if i was scraping the chassis brace at 120mm down,i could still just pull up on the drive and shove a widow maker on the sill.
Half that is more than low enough for me,though.
bland you could fit 2 jacks 1 on top of other under your 6n haha.
dan
dan
didnt meen mine was just sayin what you did for your lupo cock face :-D
it takes two to jack mine up, one to lift it one to place jack !
with a forklift!
29882_390805808045_507978045_3791355_172
