Smoothing my 16v front bumper :)
Right well I've just bought my self a spare bumper.
whats the easiest way to smooth the plate recess out?
and with the grills and towing eye cover, they can be plastic weleded and then fibre paste and then filled? is this the correct way?
is there any guides for smoothing the recess? I've looked but cant find any.
cheers
  • Replies 13
  • Views 2.1k
Need a section cut out of a rear bumper and plastic weld it in!
yea thought that would be the easiest option,
any one got a guide to doing it?
need to get a rear bumper, use card or paper to make a temple of front plate recess, trace onto rear bumper and cut out, using soldering iron basically melt the joins of the bumper and the section from the rear bumper together, do it all the way around and then just trimmings from the rear bumpper to melt into the joins to build up and strengthen the welds
once all done and cool, sand down the joins and then your onto the filling stage
Edited by mirrorblanks
I've got some pics of doing vwcherry's. did plate recess an upper grills. all plastic welded etc.... let me know an ill text you them as they on my phone
cheers, Tommy.
could always buy one off me, i'll have 2 done next week
how much?
try and get hold of a plastic welder and do it with that bud.
I've got a guide, i thought id already sent it too you preveiously?? ill send it now mate...its really easy too do the recess, the hardes part is getting the shape...I've gotta redo mine a little bit when i continue smoothing
hi pics arent great but ......
bumper melted in plastic around the edges
fiber glased and fillerd then sanded down
skim of stopper/ fine filler , primer end result
jamie
how much?
drop me a pm
i've got one
  • 7 months later...
oh ffs i wish id seen this b4 i started doing it all with fiberglass filler i spent hours trying to follow the curve line across bumper :-(
