Electric windows assistance please
Hi, I have a 1999 6N2 polo with electric windows.
Driver side electric window has stopped working (the window is up. The switch is fine, fues is fine, engine stills bogs down when switch used so power being delivered somewhere. A plastic/electrical smell led me to discover that the wires to the motor have been damaged (I can feel but not see them at the moment!) are shorting against each other. I'm hoping that getting the motor out and reinsulating will save the cost of a new motor/regulator.
My question is: how do I best get the motor out with the window stuck up please?
The motor assembly appears to be riveted to the window runner and I don't appear to be able to get the assembly or the motor out without removing the whole regulator mechanism which is a pain. I imagien with enough playing I'll get this out OK but in order to do so I'm going to need the detach the mechanism from the window and I can't get to the bolts to do that as the window is up. How do I best remove the mechanism with the window stuck up/closed?
Sqwim
ps - I don't want to risk breaking anything or having to buy new kit really as I'm selling the car ASAP. Anyone want to suggest what price I shoudl be asking for a 1999 (6N2) 1.4 16v Polo, good nick, no rust at all, 10 months MOT still to run?!
Edited by Sqwim
  • Views 919
The answer is, you don't! It's virtually impossible to get the motor out with the window stuck up/closed.
Thankfully I found that the power cable to the motor (which is behind the motor as you look at it so not easy to see/get to) can actually be removed with the motor in situ (it's just not obvious that this is the case as you can't easily see the clip). Prising the burned wires apart and reinsulating did the trick.
Sqwim
I'm gonna have to give this a go. I'd subscribed to this topic because I have exactly the same problem!
i know the window is held on to the runners with plastic clips, just wondering if you popped the clips out would the window go down?
dont matter if you break the clips, nut n bolt it back on with spacers and it should be fine(from experience)
