WISHBONE BUSHES FINALLY!
HI AFTER HAVING REPLACED THE TWO WISHBONES TWO SHOCKERS AND TWO ANTI ROLL BAR BUSHES I HAVE FINALLY FOUND OUT THE STANDARD REAR WISHBONE BUSHES ARE NO GOOD CAN ANYONE TELL ME WHAT SPORT BUSHES TO GET AND WHERE FROM PLEASE
THANKYOU
  • Views 640
Tried your local autofactors? Depends on how much you want to spend, but depending on what brand the autofactors stock they can be nearly as good as OEM parts, but then they can also be rubbish and you end up having to replace them several times over an OEM replacement, so it's swings and roundabouts, getting them from VW will no doubt be a much more expensive option though if that's your main concern...
