Fuse problem ! [probably solved]
Hi everyone !
I will do my best to make my explanations as clear as possible ! :p
1 month ago, my mk5 gti (AVY code engine) stopped working because of the blown fuse (#3 : injectors).
Once it was replaced, i could do approx. 60 miles without any problem (I point out that i was not going slowly and that i was driving on mountain roads ...).
Two weeks later (the Polo didn't move meanwhile), I took the Polo for no more than 5 miles when a second fuse went to blow :evil: (I was hoping that the problem was simply a transient voltage surge :crybaby: ).
Hopefully, I had a replacement fuse ! I started the engine and another fuse blew soon after I was moving ...
Another test the same day gave the same result (I put a 15A instead of a 10A the second times and it instantly blew after i declutched) :angry:
Without certainty, I think this happens when the engine reaches 90° and/or when i do a heavy acceleration (Is there a link with the revs ?) but as I say, no problem during 60 miles ... :doubt:
Did anyone have had the same problem or have an idea where could it come from ?
Thanks in advance and sorry for the language mistakes !
Edited by C0d3m4n
  • Views 1.5k
your english is fine.. 8-)
it is most likely that you have a dodgy fuel injector, inside a fuel injector is a tiny pintle valve that is operated by a tiny solenoid, sometimes the coil in the solenoid breaks down and makes a short circuit to ground..
you need to do a diagnostics check on the car before doing anything else, this should confirm if you have a short circuit somewhere. as far as i can remember it is only the fuel injectors on that fuse and there are no other components running from it..
also it's not good practice to use a bigger fuse, you need to fix the problem rather than using a bigger fuse
have you had a diagnostic check yet?
clearly a short going on somewhere in that system,but a check will pinpoint the problem via a fault code,and save alot of time and head scratching
beat me :crybaby::lol:
haha, faster fingers than you :badgrin:
The first time i had the problem, a diagnostic was done but no fault code appeared !
I don't understand why this fuse does not blow directly after starting the engine :retard:
My brother also has a GTi so we will try to switch the injectors to see if the problem disappears (I hope so).
And for the bigger fuse, I know it was not a good idea but that was the only solution to barely do 0.2 miles to go back to home ! :oops: I put back a 10A fuse now.
Thanks for answers ;)
the other thing you could try is to use a multimeter on the fuel injectors to see how much resistance they have.. it should be around 15 ohms, if any of them show less than 10 ohms i would suspect them as being faulty
All the injectors gave a bit more than 14Ω BUT I saw, near the connector of the first injector (the left most one when we are in front of the car), that the scotch was cut and that the wires were visible ! So this is very probable (if not sure) that the problem comes from that : the thread was touching a part of the cylinder head, which led to a short circuit.
And this is probably due to a bad reassembly by the VW mechanics during a previous panne (several years ago) :disgust:
Soon to be repaired ...
Thanks for all anyway !
