Repairing Scratches
I've just bought a Red Polo 6n and there are some scratches I would like to get rid of. The scratches are the kind that have probably been made maliciously with a key. The scratches do not go down to the metal but they do go down to the white undercoat.
What is the best way to sort out this problem? Is T Cut Scratch Remover worth a try? Touch up?
Thanks, a VW newbie!
  • Views 749
don't use t cut, it is sh1t, you want to try a compound like g3 with a machine polisher, try that with abit of wet sanding, if that doesn't do much then you'll have to ge them touched up
