should i laquer
I'm getting ma bready sprayed a satin blue, just wondering if i should laquer over the blue or will it be ok without it.
and what would look better.
cheers
  • Replies 8
  • Views 1.4k
Well, it wont be satin if u lacquer it will it :lol:
if you lacquer it with regular lacquer it will go gloss, you need a lacquer and matt/satin additive
What that man said. Like mine 8-)
yeah thats what i meant.i know it will go gloss with standard lacquer lol
Depends on the basecoat you are applying tbh
Mine was just normal basecoat then with matted down lacquer. If the basecoats is actually matt basecoat then it shouldn't need it.
not true, all basecoats need a lacquer really, but will need a matt lacquer or matting addative in the lacquer
Depends what basecoat as I've said! You can get stuff (i forget what its called) which does it all in one.
I know, I've used it at college!
if its 2k satin blue it will be ok but if its basecoat ud be best off getting sum matt laqure
