I have rust on my arches,bottem of the door and few other places
its not bad.I'm gona paint my car next week how can i sort the rust out ? can some one explain :0
  • Views 982
Rub it down with about 60 grade ali-oxide paper to take most of the rust off, then a less cause grade (120ish) around the immediate area. Make sure you have an exposed metal bit around where the rust was. Then fill it if its badly pitted. If its only midly pitted, use a high build primer on the area. Rub the filler/primer down smooth, then paint. Be sure to paint immediately before it starts to rust again.
You could use simething like metal ready or something similar on the rust to remove if its only surface, but getting rid of it is more desirable. Also, might be worth using a zinc primer on the areas where the rust was, as its unlikey you'll remove every last bit off rust, and you only need a little bit to start the rot again!
how much do you think a body shop charge ?
Its hard to say without seeing the extent ofthe rust. Take it to your local body shop and ask
