Polo 9N Torque (Dogbone) mount with a Poly bush insert
For sale I have a standard Torque mount suitable for any Polo 1.2/1.4 engines.
Should also fit the Seat Ibiza / Skoda Fabia models being the same chassis.
However it has a poly bush insert (the insert is worth £44 alone!!) PRI Racing - clicky!
Your car will vibrate with this bush whilst the revs are at 900-1100rpm.
However this is irrelevant as when you first start the car it idles at 1200rpm you feel no vibration.
After the initial warm up period your idle drops to 800rpm which is again out of range for feeling any vibration.
You will feel a slight vibration when revving up to move off the line and when in a high gear such as 4th gear doing 25mph.
This part was used for 4,000 miles so is past the wearing in stage.
I'm looking for £35 collected.
Thanks.
Edited by nick0323
  • Views 354
bump
Will take £30.
Edited by nick0323
bump.
