Will wheels with offset et30 and et20 fit on a 6n2?
Dont really understand all this offset business lol so any help is appreciated.
After some wheels they are currently on a corsa with the offset as above the guy says they rub when there is like 3 people in the back, would this be suitable for my 6n2. 15" 8j 195/45/15
  • Views 1.7k
the et30 might need small spacer to clear the strut. they would go on otherwise if it isnt mega low. then you will get scrubbage more than likely
Its not on coilys nor springys so its summat id have to watch if I decide to slam it. still need spacers? I think they fit perfect on this Corsa B which is slammed and they are both the same.
easiest way to find out is to try one on :thumbsup:
Very true lol
even though its on ebay :/
I have currently on a set of OZ racing which are ET:33 7J and the car is lowered 4 cm in front and 3 cm on the back. No scrub on the shity Greek roads.
Picture whorage :p.
If you go on ET 20 and you lower it then you will most certainly scrub, more or less depending on how low you go.
