Loose Dashboard
Hi guys,
Bought the mrs a 6N2 1.4 16v SE last month, just spent the last few weeks making it more or less perfect for her.
The last thing to fix is what seems to be a loose dashboard.
It's almost as if the dashboard has been out of the car at some point (maybe new pedal box?) and not reinstalled correctly. If you're strong enough, you can actually move it back and forth from it's mounting and every time you go over a bump, it's almost as if it's going to come off..
I'm a member on another Polo forum but nobody there seems to have seen this problem before... Google led me to this place ;)
Has anyone seen this problem before or has anyone removed the dashboard assembly from their 6N2 before?
I have a Haynes manual and it tells you how to remove the centre console and dials etc but not the complete dashboard assembly.
I don't want to start stripping it all down if there's an easier fix i.e. bolts in the engine side on the bulkhead perhaps?
Any help/advice would be appreciated.
Thanks in advance.
  • Views 1.6k
i've put a 6n2 dash into my 6n :)
what do you need to know? there's bolts on the side of it that'll probably need tightened up. Remove the caps and tighten them up. One per side.
other than that, there's the bulkhead bolts?
Hi mate, thanks for the quick response!
OK so there's bolts on the side? Cool I'll check those
Any idea where exactly the bulkhead bolts are please (Please don't say on the bulkhead lol)
Thanks again
remove the scuttle tray under the bonnet, 4 bolts holding the dash in :)
What a star!
Have I just read your avatar right? You're running a 20v Turbo in your 6n :shock:
This place is mad.. I need to spend some proper time here instead of the other forum lol - spent weeks asking questions there that nobody knew answers to and you've answered it in minutes 8-)
Panda - just a quick message to say many thanks :)
It was exactly as you said. The 4 bolts on the bulkhead were tight, however the torque screws on either side of the dash were loose (I suspect over tightened at some point by someone)
My mate and I ended up drilling a new hole and fixing a nut and bolt to it - problem solved and perfectly smooth driving experience now 8-)
glad to of helped :) quite a common fault on these... I reckon it's due to vibrations.
Oh and yes, it's a 1.8 20v turbo from an Audi S3 in a 6n open air.
Awesome!!!
