front wheel bearing 6n
need to change the front passenger side wheel bearing on my 6n,how difficult is this task?
thanks.
  • Views 1.3k
:lol: currently what I'm trying to do at the moment. Personally I'm struggling (but thats because I'm cheap and dont want to pay to get it done :thumbsup: )
If you can get a hold of a Haynes manual - it will tell you exactly what to do.
done one on a rover metro years ago and remember it being a pain in the ass to press the new bearing into hub,used a set of hub pullers to do it and swore i would never do it again but moneys tight and needs must.
got the bearing of ebay for £14 ;)
Better than I paid for mine :lol: but yea, get a hold of a haynes manual and it will tell you how to do it. It isnt the easiest thing i know that :lol:
I'm about to change the bearings on a 6n2
just need a pair of circlip pliers b4 i start!
I'm going to use a homemade clamp i made out of a bit of threaded rod and washers to get the bearings in/out. it worked a treat when i changed the rear bushes :)
job done :thumbsup:
stripped it down to the knuckle took it to a machine centre to get the bearings pressed in,circlip that held the old bearing in had to be heated to remove,it was rusted in.
pretty sure theres an faq on this
i searched and didnt find it :shock:
