What to look out for on a 6n gti!?
Right well I already know about the gearbox/clutch problems with these so only been looking at ones with the correct work done, and I knwo the cambelt is quite regular also? is it every 35k?
But over than this is there anything I should be careful of when I go look at one tommorrow?
thanks for any help
and RIP stealth 6n, soon to be revivied!
  • Replies 16
  • Views 1.9k
Check if its had a pedal box recall.
The clutch may squeek as you press it, its a sign of the welds getting weak and it may snap soon.
There has been numerous threads about this as to whether volkswagen do them under warranty, and i can say that i have rang them personally when i had a problem with mine and they said they will replace it free of charge if its a gti.(this may be certain dealerships)
Neil will be along shortly no doubt who is pretty clued up on gti'sto give you some info (he owns one also). :-D
May i point out that its a 6N2 GTi not a 6N :-p
Edited by mattyc53
thanks for any help
chances are if it's got the original bbs alloys, they will be corroded on the lip, it's ver very common so i wouldnt be too scared of that
hahaha
WELL, these threads come up faar to often. Cambelt intervals were reduced to 40k and 4 years i believe due to the amount of failure around the 50k mark. Make sure the tensioners done aswell. These tended to be pretty weak but most have been changed out now so all is good. Clutch is fine really not many problems apart from the pedal box recall. Doesnt matter if its not been done they can still go even after the recall! Its normally brought on by a heavy clutch just the weld that holds the pedal on that fractures.
Gearbox's is a old one everyones herd about. The horror stories etc. Some go, some dont, mines thundering on still on 84000 on original box. Not a hint of it failing either, regular maintenance i.e 20k oil change and observing for possible leaks around the selector shaft - easily missed it can starve the gearbox of oil. If its been done, make sure its had the rivets on the final drive changed to the VW repair kit (nuts and bolts) these are the weak point along with some of the bearings, I've seen one spit a layshaft bearing but the rivets have been competely fine (60k gearbox) so who knows really! Just dont let it put you off buying one, take it for a drive, should be sharp changes with no whines! If its from cold they are sometimes abit stiff as the oil gets warm.
When your driving it, as said listen for whines, the engines do generally whine abit, no idea really probably just the idlers on the cambelt or something but I've driven a few and there all the same. Should be no knocks from suspension or rattles from dash, Mines pretty quiet even with coilovers shaking it lol. check all the electrics the "one touch" function on the leccy windows can be abit tempremental and the rear wash wipe - again its not something I've ever experienced just going on what seems to be common.
Rust - there shouldnt be any lol. There galvanised but if theyve had wide wheels on that rub on the arches theres a possibility rust could start to creep where the paints been removed. They are gettin on for 10 years old now so bear that in mind!
neil, your a gti genius.
and we all know red is the best colour :-)
red = dread
fact.com
red = dread
fact.com
untruefacts.com :-D
red cars go faster, fact
thanks for all the advice, I've just been to look at one and although mecahnically mint just too tatty cosmetically for what he wanted, anyway my alternative (sensible) idea is to get a 1.4 match or somthing and make it a little bit special, anything to look out for on these? i know the cambelts not a big problem but how about clutch/gearbox is this still an issue?
thanks
red is the colour to have.
Though its cursed! as every red car attracts dents and scratches lol
yeh I know :) typing when tired = bad times!!
There is a 6n GTi! :p
Yeah as above, there is one around my endz :p They look pimp with their gti badge with the i in red heheheh :p
There was no uk spec gti 6n the europeans got em tho grr
red cars go pink faster, fact
Aye can't argue with that
^^ Haha
Too true,silver FTW
